I recently began evaluating Cirrus for a possible wide deployment. We use several models of Cisco routers and switches, and so far I haven't encountered any trouble with these. However, we use a large number of Dell Powerconnects (3424, 3524, and 5324 for the most part) that I am having login issues when using SSH. If I change these switches to telnet (after enabling telnet on the switch of course) the login works. Using telnet long term is not an option, and this may be a deciding factor whether to purchase.
When adding a new node for a Dell Powerconnect I consistently get 'bad password' when verifying the login. While logged in to monitor what the switch is seeing, the connection is rejected. At this point I don't know if there are recommended SSH configurations on the Dell side that I can use, but if so I'd be very interested in a sample that works for others. Alternatively, if there are any options I am not seeing in Cirrus itself other than basic credentials and SSH version I wouldn't mind being pointed in the right direction.
Thanks in advance for any advice.
