Can I run Orion on XP? Eventually it would be running on Windows server 2003, but I want to get an early look at the software. Thanks.
Magic_man,
I run Orion on XP for testing purposes and it runs fine. I would not run it in production on XP, but it's fine for testing and kicking the tires on new versions and hotfixes.
Cheers,
Orion will generally work on XP; however, it is not officially supported because XP is a desktop OS and Orion is a server application. There are some issues with XP (e.g., around the web server limitations). I agree with Ishikawa--great in the lab, but strongly discouraged for production.
