I am patching Firefox to 31.6.0 ESR. I want to disable auto update.
I have created the two files suggested by Mozilla local-settings.js and Mozilla.cfg.
I have tested them and they will disable auto update when placed under:
c:\program files (x86)\Mozilla Firefox\defaults\pref\local-settings.js
c:\program files (x86)\Mozilla Firefox\Mozilla.cfg
So I know it works manually.
I even have a vbs script that can also copy these files to its right location.
The package by itself installs Firefox fine and puts all the files including the ones mentioned above under
C:\windows\software distribution\download\install (has all files including vbs script).
My question is: how do I configure it so that it runs the script or even just copies the two files to the right location after the package has been installed?
I configured the Package Boot Editor and added After applying package:
Program name: cscript
Command line: "install2.vbs" (yes, in quotes, also tried it without quotes)
Selected - Run program from package directory
There has to be a way to run this script via command line. It does require admin rights to run the script from what I discovered.
Any ideas? Any samples of how you run a program from the command line and parameters used?
Walter
