I am looking for a report that will sow the total ports on the network and the activity for the last 120 days. If some one can give some guidence on creating the custom report of download a similar report I would be very gratefull.
Tom
Hi Tom,
Did you try to use the Historical Traffic Report named "Average and Peak Traffic Rates" and to modify its Time Frame to Last 3 Months?
Is it what you are looking for?
This report is installed by default.
Yann
Thank you for the leads I will look into hose reports as suggested
