I'd like to know if there is an existing list of all the equipements (such as firewalls, routers, servers, antivirus...) managed natively by the LEM product ?
Thx for your answers,Aïda
A list of all the supported data sources is here:
Product Pages
For an example of the devices that the LEM can send commands to, you need to look at the KB for the specific active response. If you look here: SolarWinds Knowledge Base :: How does the Block IP active response work?
You'll see the supported devices for the Block IP active response:
Our Active Response KB section (Active Response Knowledge base - SolarWinds) details all of the Active Response options.
Hi Curtisi,
It is exactly what I was looking for.
Thank you !
Aïda Daoudi
