Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Report Writer time exclusions
Network_Guru
The time exclusions no longer show up in the drop down boxes in the Report Writer.
I only see the date option. Nor sure when this broke, but I suspect it was after upgrading to V7.1
I'm trying to run an availability report for the hours between 8AM & 10PM.
Has anyone else seen this?
-=Cheers=-
NG
Find more posts tagged with
Accepted answers
All comments
jonchill
Yes, I noticed the same problem when I tried to run our WAN utilisation report for Mon-Fri 08:00 - 18:00 and the same thing happened.
You need to download the report writer exclusions again and add them as per the instructions.
Works after that.
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
Network_Guru
Thanks Jon,
That worked like a Charm!
-=Cheers=-
NG
Impulse
I tried installing the exclusions as instructed but I see no drop down boxes or any other options anywhere to set them up. I have version 7.0.5 of Orion. Do I need to upgrade to a newer version?
Network_Guru
It should work in V7.0.5
It shows up only in availability reports - as a separate item under the filter results tab.
"Date/Time (Availability time filtering only)"
-=Cheers=-
NG
Impulse
Thanks NG. Got it working.
jdhalfacre
I'm following this thread, but I have not seen any time exclusions anywhere in the availability reports. Where should I be looking, and how?
Network_Guru
Have you downloaded and installed them from the Solarwinds Customer "unsupported" section ?
It should register itself in report writer. The included .pdf file in the zipped download decribes
this in detail.
There is also some mention of this on their web site:
www.solarwinds.net/NoMaintOrion.htm
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
