I'm having trouble installing the evaluation version of NCM with SQL Express 2005. I did the SQL Express install with Mixed Mode and installed every component as well.
Here's what I entered into the configuration wizard after.
- SQL Server: (local)\SQLEXPRESS
- User SQL Server authentication: (entered sa and pw)
- Create a new database : ConfigMgmt
- Create a new account: SolarWindCM and pw
When I launch the install I get this message: An error occured configuring Orion Network Configuration Manager Database: Create failed for Login 'SolarWindsCM'.. Please Check the ConfigurationWizard.log file for details.
Here are the main error lines of the log file:
2009-07-14 11:16:23,437 [1] INFO ConfigurationProgressScene - Creating Orion Network Configuration Manager database. Processing ConfigMgmtEngine8.DBStructure file ...
Note: The time required to upgrade the Orion Network Configuration Manager database depends on the size of your database. If you have a large database this may take a while.
2009-07-14 11:16:23,546 [5] ERROR ConfigurationProgressScene - Error Creating Database.
2009-07-14 11:16:23,640 [5] ERROR ConfigurationProgressScene - Error adding sample Policy Reports
2009-07-14 11:16:23,640 [1] INFO ConfigurationProgressScene - Updating Orion Network Configuration Manager database. Updating user account ...
2009-07-14 11:16:23,640 [5] DEBUG UserAccountProcessor - Creating user login account "SolarWindsCM" on "(local)\SQLEXPRESS" for database "ConfigMgmt"
2009-07-14 11:16:23,640 [5] ERROR ConfigurationProgressScene - Exception while configuring plugin Orion Network Configuration Manager Main Plugin component Orion Network Configuration Manager Database. Microsoft.SqlServer.Management.Smo.FailedOperationException: Create failed for Login 'SolarWindsCM'. ---> Microsoft.SqlServer.Management.Common.ExecutionFailureException: An exception occurred while executing a Transact-SQL statement or batch. ---> System.Data.SqlClient.SqlException: The database 'ConfigMgmt' does not exist. Supply a valid database name. To see available databases, use sys.databases.
Have you ever seen this problem before?
