Hi
The 'Availability of Each Node' resource is sorted by the NodeID, and we want to sort this resource by the Caption.
Can somebody help me with that ?
Thanks.
Gilad.
Hi ccmc@014
I am looking into how this could be done at the moment, in the mean time a workaround would be tod create a report which shows the availability of required nodes and add this as a resource to the page you are viewing.
Tony Johnson
Loop1 Systems
www.loop1systems.com
I think Tony is right on track. With the addition of the ability to place reports on dashboards as resources, you have much more flexibility and control. I would recommend that route.
