Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Network Monitor Database Maintenance
ciarrocchif
Has anyone come accross the following scenario:
I am running the Solarwinds Engineers Edition Version 8.2 may 2005 on a workstation running windows 2000 with service pack 4.
I have set up all of my locations in the Network Monitor and it has been working fine for the longest time. When I start the Network Monitor my sites I entered come up but, the Network Monitor database maintence comes up and keeps on running automatically even if I hit the cancel box the maitenance windows keeps on coming back.
I have tried unistalling the software and re-installing it using the same cfg file I created and get the same maintenance window come back up.
I I have tried deleting the cfg and when I start the Network Monitor once again the maintence window pops back up.
Find more posts tagged with
Accepted answers
All comments
EricM
What size is the Network-Monitor.cfg file currently? Can you try opening it with MS Access 2000 or newer? If you can open it I highly recommend running a compact & repair on it just to see if this is the issue. The database may be slightly corrupt, however I cannot confirm this. Please let us know and you can also contact me at Support@SolarWinds.Net
Eric Martin
SolarWinds.Net
Technical Support
ciarrocchif
The file size is only 344kb in size.
EricM
Go ahead and try opening it in Access, then run a Compact and repair on it just incase it is corrupt. If this doesn't resolve your issue, please backup the files listed in the following knowledge base article:
support.solarwinds.net/.../ProblemDetail.cfm
Then, please uninstall and reinstall the software using Add/Remove Programs as a local Administrator on the machine; then reboot the machine. Once the install is finished, just place the files back in the correct location and see if you still experience the issue.
Eric Martin
SolarWinds.Net
Technical Support
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
