Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
IE7 & Solarwinds
aLTeReGo
Are there any plans to fix the layout of web interface of Orion under IE7 in 8.1? As you are probably well aware, things are a little askew in IE7. Does this warrant an official support request or is this something that is well known and on its way to being fixed?
Find more posts tagged with
Accepted answers
All comments
bleearg13
I've not used IE7 much at all and this may sound like a stupid roundabout way of doing things, but does IE7 have a plug-in similar to the IETab in Firefox? If so, maybe it can be used to call up IE6.
aLTeReGo
IE6 and IE7 cannot co-exist on the same computer so when using IETab in FireFox with IE7 installed on the computer you are actually using the IE7 rendering engine, which is the problem. The obvious workaround is to use Firefox but I wanted to make sure that SolarWinds was aware of the problem. I know it's a trivial issue but I get asked about it on a regular basis.
bleearg13
Hmm...if they cannot co-exist, then does IE7 create a specialized uninstall that will reinstall IE6? I ask because the one machine I've used IE7 on, I was able to successfully uninstall it and use IE6 without re-installing IE6. Believe me, I'm not doubting you, I'm just trying to understand.
aLTeReGo
The uninstall of IE7 is no different then a hotfix or service pack. All of the files that were replaced during the installation are stored in a folder located in %SystemDirectory\$NTUninstall. That way should you need to uninstall the hotfix/service pack, or in this case, the browser there is something to roll back too.
chris.conway
There is actually a seperate download for IE6 that can co-exist with IE7.
Just do a quick search on google for standalone ie6 and you should find something
Analyser Sales Ltd
SolarWinds Premier Partner
www.asl-solarwinds.co.uk
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
