Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Retaing periode
hez
Just wondering if I change the registry value
[HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds.Net\SWNetPerfMon\Settings]
"Retain Hourly"="180"
Up to let's say 360 Will this work ?
Is the limitation in the System manager (180 days) only to "protect" the DB against exsessive usage ?
/heZ
Find more posts tagged with
Accepted answers
All comments
DonYonce
You are exactly right.
You can change the registry setting to increase the hourly retention period.
hez
Hmm,
After changing the registry value, I've now get the following DialogBox when i try to go into "Orion Network Performance Settings"
Run-time error '380':
Invalid property value
If I change back the RetainHourly it open's again.
I'm currently running System Manager Version 7.7.15, would this work in a later version, or ?
heZ
DonYonce
Yep... that makes sense. Since the value is outside of the allowable range, you should get an error.
hez
But...
Forgot to mention that the System Manager disappears on me also.
So If I need more Hourly retaing than 180, I need to go into registry if I need to change something in the "Orion Network Performance Settings" Window... change it to 180 again, and try to rember to change it back to 400 before the Nightly Job, deletes all my data...
Or is there an update on this issue coming ?
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
