Some have been mentioned before, but not sure if they are on "the list".
Request 1:
Building on the following post, , it would be nice to be able to assign custom properties to the syslog table. I have a bunch of devices that for some reason do not have a feature to set the syslog source address. Being able to assign a "NodeName" to an IP address seen in the syslog table would be great, so I can filter on that and do correlation much better.
Request 2:
Having an alert action that will update a custom property. I could have sworn this used to be in Orion, but maybe I saw it in a dream once and thought it was real.
Request 3:
Ability to create a summary page that contains graphs from multiple devices, without using Custom HTML. Being able to simply select a node and interface in a resource would be ideal.
Request 4:
Customization options for UnDP graphs. I'd like to be able to set things like the upper limit, lower limit, units, and scale (logarithmic or linear).
Request 5:
Option to set custom properties on interfaces during Node addition on the web console.
Request 6:
Ability to add view limitations to more default pages, such as AllMaps.asp, to prevent unauthorized knowledgeable users from being able to put a page in the address bar and pull it up.
Request 7:
Ability to use SQL in Advanced Alerts. This can help tremendously with alerts that should be triggered if say, a custom property is configured with a date/time, by using a relative timeframe.
Request 8:
Ability to migrate statistics from one interface to another, in the event that an important interface gets moved from one device to another and you don't want to lose the stored stats.
Request 9:
Ability to do transforms in UnDP that involve more than one poller. For instance, {Poller1}/{Poller2} or {Poller1}+{Poller2}/8.
