Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Incomplete Inventory for a Cisco 2811 router
rbrewer
We are moving to Cisco 2811 routers in our environment. Cirrus works great as far as configs go, but for some reason I cannot see entity, cisco cards and other information on the Cisco 2811 router. Has any seen this before? Any solutions?
Find more posts tagged with
Accepted answers
All comments
greg
RBrewer,
A few things to check:
Check the inventory settings [Inventory Menu... Inventory settings...] to make sure that the inventories you want to run are selected.
Make sure you have done an inventory before trying to view inventory reports.
Make sure you have the correct community string and SNMP access to the devices that you are trying to inventory.
HTH,
Greg
rbrewer
Greg,
I have verified the Inventory settings and they are correct. The community string and SNMP access is correct. It works great for all our other Cisco products (routers & switches), just not the 2811.
greg
All,
Does anyone have a 2811 with the same issue?
Would anyone be willing to give us access to it?
Greg
tmeyers
I also have 2800 series routers displaying the same problems....
greg
All,
We have made some modifications to our Inventory Engine which should alleviate the incomplete inventories... It will be in our next release of Cirrus. However, you can obtain a patch by contacting Josh Stephens @ 918-307-8100.
HTH,
Greg
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
