Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Router CPU load
burgpath
While using the Router CPU load I will see periodic 'pegs' of traffic. The load will max, then settle back down. I've been trying to isolate these bursts using SolarWinds but have been unable to do so.
Anyone have any ideas that might help me locate this traffic?
Kevin
Find more posts tagged with
Accepted answers
All comments
rknight
You can run SNMP Real Time graphs on the router interfaces in conjunction with CPU Load and when the spike hits you will know what interface is taking the traffic...
If possible you can log into the router, through on a couple og DEBUGs and watch what happens in the log during a spike.
Cheers
Ric Knight
burgpath
Thanks Ric. I'll try that.
Bryan
Are the spikes chronic? Do they occur at the same times on the same days? Maybe someone is doing server backups? If you router CPU is peaking with high traffic, you may need to adjust your buffer sizes to prevent overflows.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
