I am new to Solarwinds How do I edit the info on a Dashboard I need to add a router to the Dashboard. thank you.
Another Question is How do i add nodes to a MAP.
Hi topkick - both of your questions are covered in the NPM Admin guide. For the "dashboards" you're (generally) looking for how to work with Widgets and Views. Also look at creating custom views (basically dashboards) and pinning them to the main drop down menus. I have found that it helps to make a copy of a default view and then messing around with that before making it available for everyone. For Maps you'll be working with the SolarWinds stand-alone program called Network Atlas. The atlas download link should appear a the bottom of any default map.
Thank You
Map you can add through network atlas application installed on solarwinds server.
categorized all the routers into a group and then click edit dashboard > add widget node all-Trees
Select group of routers and add submit.
Hi Topkick,
If you've not already found them, check the online courses at https://customerportal.solarwinds.com/VirtualClassrooms/#
I'm fairly new to Solarwinds myself and have found these to be of immense value as they have given me the knowledge to do what I need. Plus they are a good way to gain Thwack points too.
Good luck.
You may also look for THWACK camp 2017 Basic training
Have fun!
One of my favorite resources is the Soalrwinds Youtube Channel:
solarwindsinc - YouTube
