Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Server Time Sync
clerum
Alright, I think I may have a server (new dell 2850) with a horrible internal clock. Minutes of drift a day it seems like.
I'm currently opperating on the theory that my erratic graph behavior is caused by the inaccurate clock being resynced and throwing off the perceived time between polls.
My question is what is a good program for keeping the clock synced? Windows Server 2003
Find more posts tagged with
Accepted answers
All comments
pwinterhalder
Just use the Net Time service. You can sync it to your Active Directory domain, or from any time server on the Internet.
Phil.
bleearg13
If the server is not a domain controller, just double-click on the clock in your taskbar to open up the Clock control panel. There should be a tab in there for Internet Time.
If the above option is not available, just use the command line and set up a .bat file as a Scheduled Task:
net time /SET
Of course, there needs to be a time server set first:
net time /SETSNTP:<time_server>
clerum
Yeah but that is just a once every couple days sync. I need something similar to a unix client that polls every 1024 seconds or more depending on the current status.
jainsworth
You might try Dimension4 (D4) from www.thinkman.com. I have used it for years. It uses NTP and has many pre-configured time sources. Have not used it on Windows Server 2003 though.
bleearg13
Again:
net time /SET
Set this up as a Scheduled Task in Windows to run every 1024 seconds.
Isaac
clerum
look at this:
http://support.microsoft.com/default.aspx?scid=kb;en-us;830092
After you have taken care of this issue on your domain controllers (if you have them), be sure to sync your boxes to a good NTP time source.
To copy bleearg13:
java
try w32tm
or search in the knowledge base of microsoft. This will make sure that the time sync is not off for 5 minutes because of kerberos authetication in windows 2003
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
