Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Remote Admin Tools
jonchill
I'm having a problem when trying to connect to any of our pollers, I get an error message could not connect class not registered on local machine. I've rebooted and reinstalled but still get this error.
Also when I open the mapmaker I don't get all my current maps?
Also when I open report writer I get the default reports but no reports I've created myself?
Anyone got any ideas?
Jon
Find more posts tagged with
Accepted answers
All comments
BryanBecker
I may be running into the same problem I had. There is a remote admin fix I got from support. It basically registers a file on your desktop that you need to make it work.
As for report writer and map maker you need to copy all the reports and maps to your machine 1st. Make the changes there and then push them back to the server.
dimonet
If you recently upgraded you may want to check that the path of the upgrade is the same as your original path. Sometime it will install one subfolder down in which case you would need to copy all of your maps and custom object into the same destination in the new install folder.
Dimo
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
