Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
IIS Security and Performance on Orion
Cygnuz
Hi, i'm going to put my Orion Website available on internet so custumer can use it to collect statistics and look at their network configuration. I want to open this thread to share info about Security and performance setting and to listen your opinion about.
For internet availability https is a must-have in my opinion, so I post this link for easily implement it without installing MSCA:
www.dylanbeattie.net/.../openssl_iis_ssl_howto.html
Also I post the following settings that can affect Website performance:
from the IIS right-click on the SW website->property than select the web site tab, enable http-keepalive.
from the IIS right-click on the server name->property and select the second tab (should be server extension), click on the settings button and change parameters expecialy interesting is that about image file cache. Chart and map consume much bandwidth.
open your SW website and logon as Admin, chose andmin than setting and change the settings, expecially those about cache timeout.
I'd like to listen your opinion or your tips
Find more posts tagged with
Accepted answers
All comments
DonYonce
I suggest you turn off "Secure Data on Web". From the Orion System Manager, select File->Advanced Settings. Then select the "Secure Data on Web" tab.
Turning this off will remove access to SNMP Community strings and login/password information for your managed devices from the web.
This setting is off by default.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
