Dear all,
I wish to monitor my sans however the mib doesnt seem to be in the orion db. I have the mib. Can someone help me please?
thanks,
paul
Paul,
What version of Orion are you using? If you are running version 9 or 9.1, you can use the Universal Device Poller to create a poller to pull information from the MIB. There is a tutorial for the UnDP here:
www.solarwinds.com/.../index.html
Hope this helps.
Thanks for that, I watched the article but when I search for equalogic in the mib tree it isnt there. Also even though I have the .mib files there dont seem to be any oid's which is a bit strange so I don't really know how I can monitor my sans at the moment. If I had the OID's I could see how I could use the universal device poller (which is awesome by the way!). I'll keep trying.....
