Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
No more e-mail alerts.
pablost
I don´t know why, since today, when all nodes go down, I didn´t receive alerts anymore.I checked the connection to the smtp server with swemailnotify.exe but alerts never appears.
Any ideas??
Find more posts tagged with
Accepted answers
All comments
Network_Guru
What Version of Orion are you running ?
www2.solarwinds.net/.../topic.asp
-=Cheers=-
NG
jeffrea
I had the same problem while there was a remote control sesion to the machine. Still have not figured out why.
olsons
Did anyone find a solution to this problem? I would like to hear about it if you did. Thanks
Isaac
Hello all,
Just a thought: Did you check to make sure nobody inadvertently clicked the Temporarily Disable All Alerts box? Or possibly checked the box to disable a specific alert.
lmtaudi
What does the error log say? I had a similar problem 3 weeks back and the error was along the lines of 'unable to connect to mail engine'. The problem was that our security team had rolled out a virus def update which blocked all emails going from this Server!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
