Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Overlapping IP Space
k_fern2002
I need to manage two customer networks with overlapping IP space on the same orion box. Any recommendations of products/solutions available that will handle this.
KF
Find more posts tagged with
Accepted answers
All comments
iunderwo
You're going to need to a lot of funky NAT stuff to get that to work. Overlapping space is the least fun to deal with.
// Ian Underwood - Service Management
// Level 3 Communications
Network_Guru
In addition to NAT, you could assign secondary loopback addresses to manage the devices in each network. Of course they will need to be routable in the customer's network for you to use them for management, which may present another challenge.
-=Cheers=-
NG
clisser
We do exactly what you are describing using NATed IPs. In our case we tranlate the first octet of the customer IP using the PIX firewall at our NOC.
DonYonce
The NPM polling engines are designed to handle exactly this kind of issue. SolarWinds has many installations that monitor end-user networks with overlapping 10.x.x.x networks. The largest installation has over 60 overlapping private networks.
Here's one way of doing it without NAT-ing the end-user networks and assuming two networks with overlapping 10.x.x.x address space.
Use two NPM polling engines on two machines. (The SQL database could be on either machine, or on a third machine).
Configure the routes on each machine to point to each of the two 10.x.x.x networks... the first polling engine routes to the first end-user network, the second machine routes to the second end-user network. Monitor the first end-user network with the first polling engine and the second network with the second polling engine. All Nodes from both networks will show up just fine on the Web and in the SQL database. Reports, Charts , Views, etc work fine.
You can still use each of the two polling engines to monitor other networks also.
This particular model can be used for any number of overlapping networks without having to NAT each.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
