Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Monitor PIX 515
LCG
I have Orion 7.7.31 set to monitor my Cisco PIX 515. The PIX has IOS 6.3.4. SNMP is enabled on the PIX inside interface.
I can connect to the PIX with SNMP for monitoring, but Orion always shows the status of the PIX being down. I can see traffic going across the interfaces just fine and both the inside and outside interfaces are showing up.
Any ideas what I need to do to get this working properly? I imagine it's just something I need to adjust on the PIX.
Tony
Find more posts tagged with
Accepted answers
All comments
Isaac
Hi Tony,
Does your rule base on the internal interface of the PIX allow ICMP? Orion uses ICMP pings to determine the up or down status of a device. So while you may be able to gather statistics via SNMP your PIX appears to be down in Orion.
Be fantastic.
lcggroup
I found that while ICMP packets were allowed on the PIX, it was still blocking reply packets on the internal interface as a precaution against DDOS attack. I disabled that for the internal interface only and Orion starting showing everything as green.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
