Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
How often does Orion write to SQL DB
peel
Hello,
Is there a timeframe where collected stats are sync'd/written to the SQL database. I re-installed using my existing DB, Orion seems to be ok but the SQL database itself has not incremented filesize now for over an hour. I do have a lot of RAM on the box, is it all in memory perhaps and then at a pre-determined time it writes the data to the hard-drive?
Also once the 2gb database limit is hit (im at 300mb currently) what happens? Does Orion just stop or does older data just get replaced with the newer stats?
thanks,
tony
Find more posts tagged with
Accepted answers
All comments
Mithrilhall
I think we ran into the 2GB limit a while back and it no longer updated the database...but I can't remember for sure. We ended up upgrading to a full version of SQL.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
