Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Determining configured alerts per object
jimmo
Hi All!
Is there any easy way of determining what alerts are configure for a particular object. For example, we monitor disk space of several hundred partitions and depending on the type of information we have different alert thresholds. In order to check what threshold is set for a particular partition, I go into the various alerts one-by-one to check if an alert is set for the object. That is, I see what objects are monitored for a specific alert. I want to go the other way around and see what alerts are configured for a specific object. Is that possible?
regards,
jimmo
Find more posts tagged with
Accepted answers
All comments
snowjay
Unfortunately no.
I'm reworking my alerts to be based on custom fields I've created in the database. This way I ,or anyone else, can go to each object via the web and see what alerts have been enabled and who is getting alerted for the object.
Network_Guru
Yes there is a way, but his involves a bit of MS SQL code.
See this post:
www2.solarwinds.net/.../topic.asp
Ross Warren has kindly posted his custom SQL query that does exactly what you are asking.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
