Just installed Orion v9.1.0 and I cannot find the Map maker function. I followed the instruction in the "Solarwinds Network Performance Monitor Admin Guide. Pg 139 Please help
Thank you
There is no Start > All Programs > SolarWinds Orion > Map Maker
But I figured it out. There is a Start > All Programs > SolarWinds Orion > Alerting, Reporting, Mapping > Map Maker.
Maybe the guide needs to be update?
What happened when you clicked Start > All Programs > SolarWinds Orion > Map Maker?
Did you do the install with one userid (Windows) and later log in with another userid (Windows)?
Sometimes by doing this the profile will mask the Program lists and you'll never see them.
