Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Switch Port Mapper
westcare
When I have Switch Port mapper map out a switch I get serveral ports with multiple IP/MACs listed under them. I know this is suppose to indicate a another switch is connected. But, there is not. I'll check the port to find that only one Client is attached and sometimes it will not be in the list that switch port mapper listed.
I'm new to the tool, let me know what I'm doing wrong.
Thanks.
Find more posts tagged with
Accepted answers
All comments
MonsterMan
I too have some problems that resemble yours. When looking for a particular host with the mac or IP, I can't find it. In particular, I am searching on a layer3 switch with multiple VLANs. I can search the ARP table with no luck as well.
Anyone out there have any ideas?
Network_Guru
Have you done a ping scan of the network first from another VLAN or network to populate the arp cache of the layer3 device, or forwarding table of the layer2 device?
-=Cheers=-
NG
michaellouis
What type of switches are you both using? If you have newer cisco switches you can find the port locations of the mac addresses by using the following command from enable mode.
show mac-address-table address hhhh.hhhh.hhhh
(h representing the mac address of the client you are looking for)
this will give you the exact port number where the mac address lies off of. also use the command
show arp | include hhhh.hhhh.hhhh or ip address
to find the ip or mac address and their associated layer 2 or layer 3 address
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
