Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
hub detector
FormerMember
I am looking for a tool that will crawl a network and report any hubs that are installed. Which of your tools will do this type of reporting. I am actively looking at purchasing a product that does this. If no tools here do that, can you point me in the right direction? Thanks for your time.
Eric J Carpenter
Find more posts tagged with
Accepted answers
All comments
ceclark
We use Switch Port Mapper (part of the Engineers toolset). What you have to do is scan each switch and look for multiple MAC addresses on a single switchport.
FormerMember
i installed the trial version, but the Switch Port Mapper is not there. Any advice?
Eric J Carpenter
ceclark
Make sure you downloaded the correct version. You want this one:
www.solarwinds.net/.../engineer.aspx
Network_Guru
Just to be clear, this won't tell you if it's a hub or a switch.
It will just let you see that there is a multi-port ethernet device plugged into your switch port.
We enable BPDU guard on all our access switch ports to prevent loops in the network & alert us when someone plugs in a switch.
We have syslog alerts setup to e-mail us when a BPDU is detected & have auto-recovery enabled after one minute.
-=Cheers=-
NG
~seek & ye shall find---> [url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
<---no need to wait for answers~
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
