Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SQL question
huweimail
I have a SQL questions.
For we can see 95% percentile data in the bottom line of the web portal image, but how can I get it from the MS SQL database?
I'm using Report writer and SQL to generate a Monthly traffic report, I need the 95% percentile data to show actually the interface data traffic flow.
Does somebody know how to use the SQL to get the 95% percentile data from the database?
thank you.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
You must make a custom query in Report Writer to do this.
One thing to watch out for, is the interface collection interval changes, according to how long you keep the detailed stats, before rolling them into hourly stats & then daily stats.
Please see these posts for more details:
www2.solarwinds.net/.../topic.asp
The 95th Percentile is calculated correctly in the Orion graphs, but must be "normalized" when using Report Writer.
-=Cheers=-
NG
potissimus
Network_Guru:
quote:You must make a custom query in Report Writer to do this.
Is it possible that you could share how to get started in going about this?
Network_Guru
Potissimus,
Check this post, it should point you in the right direction:
(follow the link in this post to Don Yonce's post).
I have not created a 95th percentile report myself, perhaps someone else has - Rossw ?
I know others are using Crystal Reports to get the info they need.
-=Cheers=-
NG
potissimus
Thanks for the link, Network_Guru.
Just from a quick glance, it looks as though the attempt may be a little out of my league, but I'll look deeper into it and try to get something going. Thanks again.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
