Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
EE Switch Port Mapper sort of works
marknolo
New to SNMP but after some fiddling got my core switch and my router to reply to SNMP queries. So, Switch Port Mapper now talks to them.
When I map starting at my central switch that has servers and other switches connected to it, it sees devices and populates mac addresses on all active ports. However, it doesn't populate any IP addresses except on Port 24 where it shows tons of Mac addresses and associated with one Mac address is my entire network. Port 24 is an actual physical port that's connected to a Cisco 3524. That 3524 may have at one point been a Cisco Cluster manager, but I broke up that cluster a while ago.
Any ideas why this is behaving this way?
Find more posts tagged with
Accepted answers
All comments
rpereda
I know that others will probably have a better answer than mine. But a shot in the dark could be clearing your arp / cam.
RP
marknolo
Well I think I figured out the problem (with some help.)
My router whose ARP cache the switch port mapper queries sits outside my firewall (which I assume most of yours do also?) So, that router's ARP cache associates all IP addresses with the M.A.C. of the firewall not of the devices themselves, so when Switch port mapper maps IPs to M.A.C.s it maps them all to that one M.A.C. which is on one port of one switch. How do I get around this??
rknight
Put a router on the inside of your firewall... preferably between your Network Management station and the network segment you want to map... run ping sweep of your internal addresses then fire up Switch port mapper using the switch and the internal router and voila.. ip and mac addressing in a nice spread sheet...
Cheers
Ric Knight
Dominic
I found that the old version (v5.1.37 Sept 2002) works much better in resolving ip addresses from the mac addresses.
The new verion (v5.2.0 June 2003) gives me alot of mac addresses but returning almost no ip addresses.
I can run both side-by-side and have very different results.
I'll stick to the older version..
That was my 2¢
Ciao!
Dom
toko
I also saw this with the beta version. No ip address or host names. It worked with the one in the toolkit.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
