quote:Originally posted by BryanBeckerOne caveat I have found is you can't use the shift key with select a group of devices. The only way I could make it work is use the ctrl key and click all the devices I want and then right-click and select edit multiple devices.
quote:Originally posted by RyanJettquote:Originally posted by BryanBeckerOne caveat I have found is you can't use the shift key with select a group of devices. The only way I could make it work is use the ctrl key and click all the devices I want and then right-click and select edit multiple devices.To select a group of Nodes similar to the way you would do it using the Shift key, click and hold on the first Node and just drag down (or up) to include the Nodes you need (almost as if you were going to move the Node). You can then use Ctrl+Click to add/remove Nodes or Groups from the selection.*Note: You cannot start a selection by clicking in a blank area; you must click on a Node or Group and then drag the mouse up or down.Ryan JettSolarWinds.Net918-307-8100
quote:Originally posted by BryanBeckerquote:Originally posted by RyanJettquote:Originally posted by BryanBeckerOne caveat I have found is you can't use the shift key with select a group of devices. The only way I could make it work is use the ctrl key and click all the devices I want and then right-click and select edit multiple devices.To select a group of Nodes similar to the way you would do it using the Shift key, click and hold on the first Node and just drag down (or up) to include the Nodes you need (almost as if you were going to move the Node). You can then use Ctrl+Click to add/remove Nodes or Groups from the selection.*Note: You cannot start a selection by clicking in a blank area; you must click on a Node or Group and then drag the mouse up or down.Ryan JettSolarWinds.Net918-307-8100Ryan..I've tried this and can't get it to work. I have to manually click each device seperate to make it work. With over 700 devices my fingers hurt.BN
