Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Report writing
leo_leo
Hi
I have created a report, which shows Historical (7 dys) TX BPS of several interfaces, it is fine but how i can add sepecific time along with max Tx BPS? i.e time at which max TX bps occured..
Can anybody help me please?
Regards
K. Riaz
Find more posts tagged with
Accepted answers
All comments
leo_leo
A month and two days still waiting for HELP
Network_Guru
Ok Leo²
Try this... (I'm no SQL guru, but this might do it for you).
You will have to create a Custom SQL query to do this.
One place to start is this post from Don Yonce;
www2.solarwinds.net/.../topic.asp
Use the Report Writer and create a new "Historical - Availability" report from scratch. (this report is NOT going to give you the data you need, just an example of how to do weekly/monthly grouping in SQL).
Along the same lines as this, there is a "current interface traffic" report which also gives the time of the max. utilization.
You should be able to pull the code out of this & apply it to your existing report as per this post:
If not, then you might have to find yourself a DBA/SQL coder that can do this for you.
(I'm not logged into my Orion server right now, so I can't give you a specific example).
As Isaac says - Be Fantastic!
-=Cheers=-
NG
Cygnuz
did you use the wizard or sql?
if you worked on sql maybe you need a nested select.
leo_leo
Im using report writer
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
