Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Export nodes from Orion in a CSV file
keist
Why is the option to export nodes to file disabled in orion i have another management platform that i want to use Ciscoworks specifically for software management of switches and routers it allows you to import an CSV file for nodes but orion does not allow you to export, the choices in orion are grayed out.
Dan
Find more posts tagged with
Accepted answers
All comments
DonYonce
Dan,
You need to select something to export first. In this case, select a View from the toolbar (or create a new view). The export selections will then be available.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
