Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Anybody have issues with Orion 7.7 Installation
bpaley
Anyone else have any problems installing Orion NPM 7.7? I am getting a runtime '5' error during the "Welcome Screen" in Configuration Wizard. Everything else (SQL, Website, and Services) installed fine and the website is up and running but when I try to login to Orion System Manager it says it's "Connecting to Polling Engine" and then it shuts down. I am unable to get in to add/edit/remove nodes. Anyone else experience anything like this?
Find more posts tagged with
Accepted answers
All comments
jonchill
I haven't had any problems since upgrading to 7.7, went like a dream. The first time I tried to connect to the system manager I got a similar problem but I restarted the server and gave it a while and tried again and it worked fine.
Jon Hill
IT Infrastructure Manager
Pilgrim Hospital
UK
mjhamilton
I am running 7.5 and am going to upgrade to 7.7.. dumb question.. is this a straight install over the top or do I need to unstall the 7.5 system and leave the SQL database in place???..
I know it sounds dumb but the admin guide says uninstall the app only v6 or prior.....
I am guessing that with 7.5 the straight over the top upgrade will work
Martin J. Hamilton... lost in a sea of snmp...
jonchill
I upgraded from 7.4 and put 7.7 straight over the top I took a backup of the web site and Orion config just in case, but the upgrade worked a treat and I had no problems.
Jon
Pilgrim Hospital
UK
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
