quote:Originally posted by BakerDWe came up with our own little web front end. This only took a couple hours and is good enough for now, but if SW doesn't come up with an IP Address Management solution for NPM, we are either going to have to write our own or purchase one already out there. I also don't think just pulling the data from the EE toolset is the way to go, I think NPM needs its own version. Features I would like to see so far: Be able to add/edit/delete networks from browserList all IPs in a network, not just ones that respond. That way IPs that are out there buy not reachable would still be listed.Be able to set networks or even individual IPs to not be scanned or skipped. Again useful for IPs that are used, but not necessarily reachable. IE external IPs or DMZ IPs that I know are used but I don't need them pinged to see if they are live.IPs stored with three 0s for each octet to allow proper ascending/descending sorting. Right now a sort shows up like10.1.1.110.1.1.1010.1.1.10010.1.1.101.......10.1.1.11.......10.1.1.12.......10.1.1.2and so onThe zero's I believe could be stripped behind the seens but would be stored in the DB for proper sorting.10.1.1.1 --> 010.001.001.00110.1.1.2 --> 010.001.001.002 and so onA couple custom text fields that a customer could label to their needs and use. IE I would like to not only have comments, but another field that I could add in where/how a server is backed up.Search function as we have implemented.Able to use SQL DB instead of access or MSDE for performance.PS Also we have used [url="http://www.infragistics.com"]Infragistics to create our tabs within the webpage and also to create the web interface to the IP DB which gives us all the functions of navigation, drag/drop columns and sorting etc. A lot can be done with their product and we already had it for other needs, so it might be kind of pricey if you are just looking to add tabs as we did.
quote:Originally posted by asl-supportIt's currently under going a complete rewrite so that it should be possible to add/remove subnets, mark addresses as used/reserved, change the polling frequency etc.Analyser Sales LtdSolarWinds Premier Partnerwww.asl-solarwinds.co.uk
quote:Originally posted by asl-supportDoes anyone have something else they would like to see implemented?Chris
quote:1) Be able to add/edit/delete networks from browser 2) List all IPs in a network, not just ones that respond. That way IPs that are out there buy not reachable would still be listed. 3)Be able to set networks or even individual IPs to not be scanned or skipped. Again useful for IPs that are used, but not necessarily reachable. IE external IPs or DMZ IPs that I know are used but I don't need them pinged to see if they are live. 4) IPs stored with three 0s for each octet to allow proper ascending/descending sorting. 5) A couple custom text fields that a customer could label to their needs and use. IE I would like to not only have comments, but another field that I could add in where/how a server is backed up. 6) Search function as we have implemented. 7) Able to use SQL DB instead of access or MSDE for performance.
quote:Originally posted by asl-supportGood News !The work I've done on this so far is working with my Alpha copy of Orion V8.Analyser Sales LtdSolarWinds Premier Partnerwww.asl-solarwinds.co.uk
You have to remember I'm doing this when I have the time to do it.
As I'm in the office now until January, it'll probably be a few weeks until I even look at it again.
quote:Originally posted by asl-supportYou have to remember I'm doing this when I have the time to do it. As I'm in the office now until January, it'll probably be a few weeks until I even look at it again.Analyser Sales LtdSolarWinds Premier Partnerwww.asl-solarwinds.co.uk
quote:You have to remember I'm doing this when I have the time to do it.
Just wondering if this is still in development or is it a dead project? Was really looking forward to this.
Seeing as the whole top section of the web interface has changed in 8.1 I need to figure out how to include new module options again........
As I've said before, I'm doing this when I get time....... Which at the moment isn't that often due to an increased workload
As with everyone else, I am very interested in this too. I am already publishing the ip scheme to a page and have a link from the home page to it, as well as many other items, and would love to put this stuff on tabs.
Thanks for the update. I was just curious as I did not see any postings in 6 months.
