Hello,
Is there any possibility to exclude “Bandwidth” value on cellular interfaces from changes. This value is changing automatically based on 3G signal and the management doesn’t want to kiwi to report it as change.
What device type are you using in CatTools?
Can you give examples of the lines you want to ignore please?
Kind regards,
Wardini
I am using cisco 3G router
here is a sample
But which device type in CatTools have you chosen for your 3g router setup? Cisco.Router.General, or Cisco.Switch.IOS, or something else?
Cisco Router General
