I want to monitor access points from the controller. i can retrieve the values from the table via snmp. to see the values, I created two UnDP (AP name and AP status). The two UnDP access the same table.
then I created the alert with "Custom Table Poller Current Status"
this only monitors for status. therefore, I only see the status if the ap is disconnect but not the name of the ap. how can I adjust so that i can also see the name of the ap?
