I like the ability to create an Orion Map. My question is how do I get a node to only show its that map. For instance, I have a Cisco 4500 switch with 2 6k power supplies. From there I can create a map, add the widget to the node summary page. It displays the map that was created. However, when I look at another 4500 switch, it shows the map of the wrong node. Am I missing something. I am wondering if I can apply a certain map to each node summary view with just that devices map?
Rob
