Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Remote Admin Utility Issues
BryanBecker
Not sure if anyone is using this tool or not. It's the Remote Admin suite which basically allows you to run Systems Manager/Report Write/MapMaker, etc. from your machine. The applications basically connects to the server's DB and allows you to make changes without having to log locally to the server.
I've tried on both XP and 2000 to get this to work and I'm not having luck. I run the configuration wizard and it connects to the server DB without any problems.
Once I tried to run Systems Manager it says its connecting to the polling engine and then I get an error :
NetPerfMon
Cannot connect to XXXXXX (server name here)
Everything from an SQL perspective looks fine. I can run SQL Manager and connect and query the DB.
The version of the tool is V7.0.140 December 2003
Anyone have run into this or have it working? Thanks
Find more posts tagged with
Accepted answers
All comments
Network_Guru
I've heard this Remote Admin tool was to be sold as an add-on to Orion, but I have never seen it. I don't know how you got a hold of it, but I've been asking for this for some time now. I was planning on using this to resolve our LSASS - RDP session issue.
Looks like you are on your own on this one...
-=Cheers=-
NG
iunderwo
You'll have to email support to get a quote. I use a remote web engine on my installation, and it was a little extra. It's especially valuable since the location of my poller requires very strict firewalling.
I have an SLX installation, so I'm not sure if those addons are available for smaller licenses.
// Ian Underwood - Service Management
// Level 3 Communications
BryanBecker
If you email Sales they will get you a quote. I worked with support and got the issue resolved. It's about $500 a license.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
