How do you config cattools to backup juniper srx?
Can you try Juniper.Router device type?
Wherever required, use Variations feature to change the commands.
If the above is not worked out , you can try the same with Generic.Device type
If that is also not worked out please capture the PuTTy log by following below link, then I can check with the existing templates and update.
http://knowledgebase.solarwinds.com/kb/questions/127/Get+support+for+your+device+added+to+CatTools
Nanda
Hi Randa-
I am currently using Juniper Router Device type still no luck. Below is the error message I receive.
2014-03-17 00:00:51 csva2srx01 Did not receive VTY entry prompt from Juniper Router
David Wong Director, Network Engineering | comScore, Inc. (NASDAQ:SCOR)
o +1 (703) 376-6609 | dwong@comscore.com<mailto:dwong@comscore.com>
comScore Media Metrix Multi-Platform: Audience Analytics for the Brave New Digital World
www.comscore.com/multiplatform<www.comscore.com/multiplatform>
Can you please share the debug log?
This can be found @ Debug folder by enabling capture mode in File menu.
