I have a bat file that is pointing to a txt file with parameters to use for installing the exe. If I put the bat file in "Before Applying Package" after a little bit the exe kicks in and starts installing. I would like the bat file install to do all the install and configuring with the parameters. Is there anyway to do this or another way I could just have this bat file do the install?
