Hi folks.
My problem is as follows:
When i use the "edit chart' option in any chart, for example "average CPU load". and i use the default options (sampling every 10 minutes, last 24 hours, etc) the graphic is correct, i see a sample any given time i choose. But when i use "custom" option and i select a window of time, let's say a day between 12/20/2011 10:00 AM ~ 12/21/2011 10:00 AM the graphic seems interrupted, and limited to a sample every hour, only one sample every hour. That's not correct. Anyone could tell me if this is an expected behavior, or i need to so something else to make this work? thanks in advance.
JJ
