Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Creating a new alert
dhutchings
Guys,
I'm in the process of creating new alerts. I created two alerts earlier today that seem to work fine. I tried to create a third alert to find that it is not populating the "Monitored Network Objects" field. It just comes up blank. I've tried creating new ones and making copies of existing ones and either way, the field just doesn't populate.
Yes, I have performed network discovery, and the initial two alerts that I created populate the "Monitored Network Objects" field no problem.
Thanks for any hints,
Darren Hutchings
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Darren,
What you see in the monitored objects field is based on what you have checked off in the "property to monitor" field. If you have selected a property which you are not currently monitoring, then the monitored network objects field will be empty.....
-=Cheers=-
NG
dhutchings
Ahh. Okay, next question then, is how do I select volumes as monitored properties en masse as opposed to having to select the volumes on each monitored node individually?
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
