Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
I need GREEN when interface is down
dajomas
I use ISDN as a backup for my main lines. When I add the interfaces to Orion, they are down which is good but they show RED and are thus seen as a problem.
I would like to see those lines GREEN when they are down and RED when they are up because that means something is wrong. An additional problem is that these ISDN lines can be used for user dial-in as well. So when a user connects (using a different dialer interface than the ISDN backup) I don't want to set off an alarm.
Does anyone have any experience with this? Or does anyone know how to set this up in Orion?
Thanx
Johan.
All bits and bytes contained within this message have been recycled and are not tested on animals
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Do a search in this forum for ISDN.
There are users which have posted about this issue as well.
www2.solarwinds.net/.../search.asp
-=Cheers=-
NG
bripage
Hmmm... another dead link.
Network_Guru
Hey Brian,
You can use the search link at the top right of this page instead of the broken link...
Just remove the dash between Solarwinds & Forum in any broken link on this Forum & it should work again.
-=Cheers=-
NG
Troy8181
We had (kind of) a similar request. Instead of a node turning yellow, we wanted ours to turn red. We found the icons we wanted and simply renamed them to change the color of the icons when things went up and down.
I believe we changed them on the Solarwinds server at C:\program files\SolarWinds\Network Performance Monitor V7\Maps\NetObjects\Icons
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
