Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SNMP running but I can not add node
teano
I downloaded Orion NPM from SolarWinds website. I installed and ran evaluation version. And I tried to add node, I wrote the IP address of the router, and the community string which I defined in the router configuration before. But I got an error message telling that it can not communicate with the device using SNMP.
I'm using Windows 2000 Server. And when I controlled the services on my system, I saw that SNMP service is running.
And also it's so interesting that altough NPM proggramme can not add device by using SNMP, it can find my router when I use the Network Discovery Tool.
I couldn't understand what the problem is.It's because of the Orion Evaluation version? Has anyone got any idea about this matter?
Can anyone send me a reply as soon as possible? Thx so much...
Find more posts tagged with
Accepted answers
All comments
dimonet
Just as a tip. SNMP strings are case sensitive. Also make sure you are not running any access list which would prevent the polling engine from gaining access to the device.
Dimo
clive.churchyard
Hi
You need to make sure the config of your snmp service has the correct community string attached and that the security is set to allow the request from the management server.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
