Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Future Features
Haych
I am probably asking questions that have been asked before but, will Orion ever support SNMP Traps or the ability to add additional MIB's?
Seems to be the only features lacking in a great program.
Find more posts tagged with
Accepted answers
All comments
iunderwo
Those are two of the most-frequently requested features...not sure if they'll have them in before v8.0, though since support for those may require some underlying architecture changes.
// Ian Underwood - Service Management
// Level 3 Communications
Network_Guru
Yes, these are major changes which many of us have requested.
Managing the devices has become quite complex & time consuming (since V5) now that there are so many new
features to manage. Here are some major management improvements that would benefit all customers, but in
particular, those with very large networks with hundreds if not thousands of devices to manage.
Right clickable menu in System manager with the following capabilities:
- add current device to any number of existing alarms/alerts
- disable/enable alerting for current device (maintenance mode)
- assign custom properties in Custom Property Editor to current device
Alarm/alerting configuration based on custom properties; e.g. by type, owner, region, time, circuit number, etc.
Filter list of devices in the Alert configuration Window, based on custom properties of Node or Interface.
These features would go a long way in simplifying the daily management of devices.
Other features which should be easy to implement or add:
Reports based on 95th percentile usage.
Reports based on assigned value - only show nodes with less than 100% availablity for past week, all nodes above xx% utilization
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
