Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
"links" in the map
kreischl
I like the feature where I can assign an interface to a link in the map. However, that's only one of the two ports used for that link.
Has anyone come up with a work-around?
Is there a way to make a link that doesn't connect between two nodes? I was thinking of having two links separated by some small graphic so that I know the left part is for the link on the left node, etc.
thanks
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Yes you are correct, you must use 2 separate lines, one for each interface:
www2.solarwinds.net/.../topic.asp
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
