Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Server Room Temperature Monitoring
bmcclln
Can Orion v7.8.2 be setup to monitor the temperature of a server room and how? I presume the air conditioner will need to have SNMP capabilities to accomplish this. If it doesn't what inexpensive options are there?
Find more posts tagged with
Accepted answers
All comments
jonchill
Currently Orion does not support custom mibs, but hopefully this will be sorted in the next major version. So whatever solution you decide on you will not be able to get the stats in a Orion until mibs are supported.
We use the enviromental monitoring capability of our APC UPS.
Hope this helps?
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
mjhamilton
The bad with is that Orion currently has no custom MIB capability so you will not be able to monitor data like this through this application.....
you will need a network enabled gun tooting snmp supporting aircon unit to do this (big bucks).. however for about £300 ($500) you can get a dedicated snmp module with a temperature and humidity adaptor....
www.sinetica.co.uk/homepage.htm
netcom-th should do you... you will need to order the TH module... it will also support contact closure UPS's as well... Sinetica also have an app called EDMS which can interface with the unit, log data and notify in the event of issues.... I use these in both my datacentres for power and climate and they haven't let me down in 4 years...
Just a thought
Martin J. Hamilton... lost in a sea of snmp...
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
