Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Getting number of user from Foundry
Oct_7
I have a client who needs to know how many user connected to their foundry load balancer (ServerIron XL SW ver.7.3.07dT12). Anyone has done it before from Orion? I do not know whether it has OID for it, what I know is that you can use telnet to get the number. Any idea how to capture the number from telnet and show it in Orion?
Thank you very much,
Best regards,
[] [_] [--
Find more posts tagged with
Accepted answers
All comments
Cygnuz
Not sure but I think you need to change one OID of the server MIB customizing it, so if you are under unix any query to that OID shuld map and execute "ps aux|grep "telnet_shell or someting like this"|wc -l". Don't know if it work but is just an idea. You can also see if Application or Service monitor can do it. Hope this Help
Network_Guru
You require a Custom MIB for this, which Orion does not currently support.
We use PRTG to pull this info from our load balancers to graph this info.
You might also be able to pull this data using the Solarwinds EE Custom Mib grapher.
It has an option to publish the graph to a web page, which could be on your Orion server.
-=Cheers=-
NG
Oct_7
Cool,
I will try it later then. Thanks a lot for the help.
Best regards,
[] [_] [--
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
