Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
clear counters not working
DaveNoonan
I want a scheduled job to clear counters on a bunch of IOS devices at midnight but the commands don't seem execute. The script is "clear counters${CRLF}${CRLF}". I've also tried "clear counters${CRLF}y${CRLF}" and replacing the ${CRLF} with a carriage return. If I add "sh ver" in front the clear counters the "sh ver" will work and then it will hang for a while and eventually finish. In the output the "clear counters" command never shows up but the "sh ver" and it's output do. I have the same problem whether I do it from "test job" or from "upload script".
I also tried "clear log" and got the same results so it's seems to be related to the "clear" command, even if you abbreviate it as "cle". I can paste the identical commands into a telnet session and it works fine so I really don't get what the problem is.
Any ideas?
Find more posts tagged with
Accepted answers
All comments
DaveNoonan
FYI...
I finally found the form to contact support (they do hide it, don't they), opened a ticket and we determined that Cirrus doesn't recognize the "[confirm]" prompt that the router sends after you ask it to clear counters, logs or a number of other things.
I'm waiting to see if there's a fix.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
