Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
scan subnet every X days
FormerMember
Can anyone provide some insight into how the subnet scan works? If I have, say, 400 subnets in a IP Database and they are all set to scan every 7 days, after a week will it:
a) begin a scan of all 400 subnets at simultaneously (parallel)?
b) begin a scan of all 400 subnets one after another (serial)?
c) scan each subnet exactly 168 hours after each subnet was created in solarwinds (staggered)?
Find more posts tagged with
Accepted answers
All comments
davemac
Not sure...Does it matter? It will only run the scan anyway while you are logged in and have the tool running.
I created my subnet list one subnet after the other in ascending order and what I find is that it scans the subnets randomly not sequentially. While the tool is worthwhile i'd like to see an option where it will clear the subnet list first before scanning otherwise you end up with IPs no longer in use (particulary if you're scanning your DHCP range too) still showing as allocated. I know they have the last response time but still.....
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
